Fuel tank pickup screen
Rico
San Diego
Should I get a new pickup with screen or because I run efuel just get rid of the screens? Anyone just get rid of the pickup tube?
Rico
San Diego
Well I’d live to do my own version but with my luck that won’t work out so well. Just looking for some wisdom
79jasper
skiatook, Oklahoma
If I were to go through the trouble again, I would get sumps.
But... I just ran some diesel rated line to the bottom of the tank with a brass t on the bottom. (So it doesn't suction to the tank)
Sent from my SM-G892A using Tapatalk
Rico
San Diego
I wanted sumps but spent pretty much all of my money with a new oil cooler/rear mount, wiring harness, bypass oil sytem and so on. :/
ghohouston
Lewisville,Texas
I'll give my personal experience here. My 97 broke both shower heads off. Left my buddy stranded 3 hours from home when i let him use the truck. Clogged my selector valve, and it stuck between positions. Bought a new selector valve, dropped the tanks, cleaned, went along with my business. I have had nothing but problems since. Anytime the truck is ran below 1/4 tank, it sucks up yet another piece of rubber into the sending unit, because unless you have like 6 foot long skinny arms, you can't properly clean out an obs front tank. I thought i had gotten everything out of the front tank. Had a flashlight and mirror in the tank and everything last go around. Left the old lady stranded a few days ago. I will be swapping to a sd 38 gallon front tank soon, and it will no longer be a problem. They cause nothing but problems, and WILL fall apart. Im sure there is either a metal contraption with a screen to rig up on the sending unit if you're that worried about it.
ghohouston
Lewisville,Texas
Its a few compression fittings, some steel brake line, and a tape measure, it's fairly easy if you're at all mechanically inclined.
DieselDC
I don’t use mine - took them out long ago. Those screens are too restrictive imo. Bought an extra sending unit from @Cletusjermal that had the hutchmod deal done on it and it’s going into my 60gal :) Titan tank.
Another idea I had was to just make my own pick up tube and use 1/2 “ tubes for both the suction and return. 1/2 back down to 3/8” to plumb right into the stock lines.
DieselDC
Yeah mine has the screen assembly completely removed and just a pipe straight down for fuel. Never had any issues. Never had the 1/4 empty deal either b/c I didn’t keep the rubber foot on there for too long.
Rico
San Diego
Ok great. I would rather get rid of the black plastic pickup boots. Bought two for $70+. Wish I didn’t do that. Can still return one hopefully
