question about removing egr
kcstreetracer
ok i have a quick question.
i have a *** and egr ******d tune from tyrant. would it be possible to install the exhaust and go ahead and tune it and just unplug the egr until i have time to install the block off plates and remove the pump? will probably be a few weeks until i can do it.
Tune first and start the truck to make sure all is well. Then remove exhaust. EGR doesn't have to be actually removed unless you choose too.
kcstreetracer
Ok. Thanks. Im assuming after i tune before i start it i want to make sure all the exhaust sensors are unplugged and also egr is unplugged?
kcstreetracer
one last question!
what about the egt sensor if im just leaving the egr system in and not installing a block off plate for awhile?
kcstreetracer
Just leave it alone. You just won’t be able to read EGTs
So is it necessary to unplug the egr connectors? I can only find the one on valve. Can't seem to locate the 2nd, I guess I'm blind
Sent from my Pixel 2 XL using Tapatalk
Ackerdiesel
Western Ky
Pull the air intake and look toward the base of the cold side pipe. It’s toward the back side (engine block side)
