TCM flash with Ford IDS vcm
Luciano
When replacing the TCM unit on a 6.7 what's the procedure to get the new unit to communicate with the other modules? Also does anyone know of a place where you can't rent/borrow a Ford IDS scan tool?
78f100
Bonifay FL
Your best bet is gonna be take it to a shop that has a IDS. In the IDs you have to go to install a new module, it will check if there are any later pcm or tcm updates, if so it downloads them erases the current programming in the module and reprograms. It usually will reflash the pcm tcm and any other module it needs to update.
Luciano
So if the truck has a tune on it would you need to return to the stock tune, reprogram the modules, the reload the tune?
78f100
Bonifay FL
As sootie said yes, pretty much any module that needs programming you always want to return the PCM to stock first.
