6.4 Gone. 2017 6.7 F350 Platinum In.
Black AOD
Ohio
Thanks Guys. I have some preliminary pictures that UDP sent me but i'll get some better pictures tomorrow that I can post for everyone tomorrow.
Black AOD
Ohio
Here some pictures of the Remote Filter Bypass Kit. I snuck in a picture of the freshly built WDI 6R Trans as well and the new OUO ALAs too.
Sent from my SM-N975U using Tapatalk
harrelljr99
Very nice and Merry Christmas Andrew!
Black AOD
Ohio
Truck got cleaned up and my SF 22x12s are gone now. They got some replaced by some SOTA novakane 20x10 and 305/55 Toyo AT2s
Truck is an absolute blast to drive now. WDI Trans shifts absolutely perfect, it holds the power very well now. I have had to make a couple trans tuning tweaks with Chris but overall I'm very pleased. The ALA's and the new FOX Steering Stabilizer out of OUO's steady axis steering kit has literally completely changed how this truck drives, it's amazing the difference they made. Literally night and day. It drives so damn well now.
Trans cooler is almost too efficient with the colder weather, I may have to block of the cooler during the winter here because the Deltas are so drastic.
The remote oil bypass filter kit dropped oil temps as well since the remote filter is basically acting as a heat exchanger being mounted on the passenger inside frame rail. So Oil Temps dropped pretty drastically too. The trans being so cool is also causing the Oil temps to be low as well. I honestly never thought this would be the problem I face with this setup! Haha.
Blocking off the trans cooler should allow trans temps to rise a bit which in turn should help the motor (oil) temps rise as well. We will see if this is the case. If not, I may look into a shutoff or block off valve for the trans cooler or the oil filtration kit.
Black AOD
Ohio
Pictures of the FOX ATS stabilizer from the OUO Steady Axis kit and the new Hellwig Rear Sway bar as well.
99fordman18
Let me know if you decide to part ways with the 22x12 SF. lol
Black AOD
Ohio
They will be for sale once they are re-machined and re-coated (same color as before) to fix the curb rash. There will be 5 wheels total, 4 with matching billet center caps.
alewis
Nice set up! That remote oil filter looks yuuuge! The diesel site trans cooler I assume?
Nice looking truck too.
Black AOD
Ohio
The filter is humongous, it is no joke.
The kit is Strictly Diesels secondary trans cooler.
Connor M
Masshole
Saw it on instagram but had to checkout the oil filtration here.
I’m glad Jim’s still doing that I thought he was out of the industry or something now.
Once my stuff actually runs I’ll want to get one, lol.
Black AOD
Ohio
Yeah Jim is more quiet these days than he used to be. He left LE a long time ago and he no longer is a dealer for them either. He can still get it for us folks that want to buy it though. Hes still doing TONS of lubrication and filtration type work in the background but it just doesnt get posted on social media because he doesnt give two shi*s about posting on there about his work I dont think.
As far as my setup, so far his remote filter kit is badass. I'll be interested to see how my oil looks at the first change.
Connor M
Masshole
Is ELS still open? Just not a dealer for LE I guess?
Is he still trying to do anything with dieselpros.co? I thought that was a great idea. Idk if it’s profitable if hes no longer a dealer though.
Ordered oil from him in like August. Still my fav guy to get oil from.
alewis
How long did the trans cooler take you? I’m probably going to put one of those on... I’m in Louisiana where it stays hot and that would be a good addition for those heavy summer tows.
Black AOD
Ohio
Yeah Jim still runs his company ELS, he just isn't a dealer for LE anymore I don't think. You might want to ask him that directly to confirm it 100% though. I was buying all my LE stuff from him, still do. Unlimited Diesel has a bulk tank with 8854 engine oil now though so that's nice because it's local (ish) to me.
Black AOD
Ohio
UDP did it for me when they installed the trans so I'm not sure. It looks pretty simple though, I was told the grill needs to be notched slightly on the inside to run the new cooler lines to the cooler itself. I'd guess 2-4 hours to install it based on experience from what I can see.
Connor M
Masshole
Damn, I’d love to find a place with bulk 8854.
Honestly I should probably buy a 55 gallon drum considering I have 3 6.4’s in my shop, 3 6.0’s, and 3 3126 cats, and my dad’s 6.7.
Plus some isuzu/mistu 4cyls that probably can run 5w-40.
