Wastegate Control Solenoid?
I have a 98 E350 (early 99) and I am getting this trouble code. How am I getting this code if I, the vans, don’t have a wastegate?
Magnum PD
VA
The sensor is not seeing any pressure probably. Need a ****** pigtail
Magnum PD
VA
Is everything stock? Computer should already know there is no wastegate.
Is there anything on the spyder? Like a harness?
My spyder on the van looks like this. Directly out of the turbo and Y’s into the intake plensums, except mine doesn’t have that that intake heater or whatever that is. It doesn’t even have the port there for it.
Magnum PD
VA
Wish I knew more about the van setups. The harness is different from a truck obviously, so the PCM should be different also. Was the computer swapped at any time?
Not that I know of. I am ordering an EBPV d*lete and a 470 ohm 1 watt resistor to connect into the plug that connects to the pedestal so the “soft code” will hopefully go away.
