High boost indication
Jbonfiglio
Oregon
Hey. I’m getting almost 20psi at around 1500rpm going about 40 mph with zero load. I changed the EBP sensor and tube. Truck is deleted but the EGR and coolers are still in place. Anyone else have this issue that they’ve resolved?
Jbonfiglio
Oregon
What does it read KOEO?
And the port was cleaned also right.
Zero both and I don’t remember if I cleaned the port. Could a clogged map port cause that?
Jbonfiglio
Oregon
Remove and inspect the map sensor, I bet it and the port in intake are clogged
I removed the sensor again last night and it’s completely clear. Even though my EGR is deleted
could it still cause an issue like this?
