2013+ steering gearbox in older trucks
Powerstroke Cowboy
Montana
I’m not sure on the 11-12, but I just put a brand new 2016 steering box in my early 08 with a borgson shaft and it’s 100% bolt in and a huge improvement. I would think all 6.7 boxes from 11-16 would be the same? Only thing I had to get was the 3 bolts for a 2016 as well, the threads are larger than the 08 bolts.
So you just used bolts from the 2016 pickup?
How do you like the Borgson shaft compared to the factory shaft? Did you do the upper and lower shaft?
Is the 2016 box better than the 2011 box? My parents 2011 has way tighter steering that my 2008 does. We both have over 300k on as well. The 2011 is still tight and mine had slop.
ncollins64
winchester springs, tn
I just got the lower borgson shaft but it’s a noticeable improvement, the factory one wasn’t bad but said since I’m in it this far might as well. And I just went through ford and got 3 new bolts for a 2016, the 08-10 boxes have smaller threads. I would think the 11-16 would be the same but I have not verified. When I ordered it, I wanted the newest possible, but with the shaft and new box, the steering is way tighter and better, well worth the money, for the originals sake it did have over 200k on it too.
TPOLO
CO
Any chance you can write out a parts list that you used? I plan on doing this 2011+ steering gear upgrade along with the shafts on my 2008.
I know it definitely needs new bolts from 2011+.
Shaft and pitman info is all over the place.
If you could confirm the parts and any additional info, that would be amazing!
Thanks
