Lifted trucks
Ia PWRSTKE
Meriden,Ia
They look like bfg km2's
They are the limited edition bfg km. Just before the km2 came out and they were a 335.55r22 only. I had em and I liked em cause they were different.
John@Outlaw_Diesel
Pittsboro, IN
6" lift, 38x15.50x20 kumho's and 20x10 rockstar's
6" lift again, 37x13.50x18 Procomp on 18x10 eagle alloy's
6" lift on 35x12.5x20 Cooper STT's with the 20x10 rockstars
most recent, pulled leaf out of front 6" spring pack, also went down to just factory F350 rear block. Sits about dead level now.
dstryr
Gilroy CA
More pics of the red truck please!
Me? I'll grab some more pics tomorrow when I finish the install. King supplied carli with the wrong shock spacers so that my shocks move in the mount so I didn't want to drive it.
Ended up machining my own track bar spacer like we talked about and then found it on the ground an hour later. This is what you get for having friends help with the install :lame:
On a side note I got the last set of General Grabbers that 4 wheel parts had in stock (country wide). They look badass.
07_powerstroke
Upstate, NY
What does the lift consist of? Damn did you contact Carl I about the spacers?
semperfidooordie
Fairbanks, AK
Thinking about running some real wide singles on my truck and some nice wide tires....any advice for the offset to look for? Also what kind of lift I'd be needing for 40s and up on the truck in my sig? I don't like the 18" lift with 33s...more of a fan of the semi-stuffed look like the 37s with a leveling kit...
mallardslayer07
This one is just a quick shot from this morning...
