Stock Cam Bearing Walk
Marty
Elkton, MD
Has anyone else ever seen this?
Hotrodtractor
Mingo, Ohio
Is that a rebuilt motor Marty? I've seen where the tolerances on the cam bores are a bit on the large side and the cam bearings don't have the right press fit. I've never seen it on a high mileage motor from the factory though - unless its cracked...
Super 6.0
WYO
iv seen a block crack through all the webs and the crank mains but my first guess would be a bad fit on the bearings. maybe the tolerance was too far out? :confused:
Big Bore
9000ft in the CO Rockies
Probably the same roller lifter that is in every 7.3. They are hydraulic rollers from the factory.
I was wondering about that. All the blocks I've been in still had the cam in place. Now how about the source for those roller rockers?:poke:
I've been concerned about the possible increased wear on stock rockers from high pressure springs.
Pardon the thread jack Marty.:D
Marty
Elkton, MD
I haven't looked at it since.... been way too busy honestly. I hope by the end of next week I will be caught up.
