Vanilla Ice buildup thread....
PTSUPERD
Just an update guys. Matt is pretty much done with the tuning...but he could only go so far. The turbo will only make 26 psi. RCD street file would only make 26 psi for me as well.
With the live tuning, normal driving and runs to half throttle are smoke free. He can jack the backpressure way up and get it to make 30 psi but thats it. EGTs are still toasty. No chance of towing.
He says the way it is now, the truck is running clean and a blast to drive....but turbo wont build boost. Says it makes good power....but is being held back.
I'm hoping to get the batmowheel off of it and see what it does if I can get my hands on a cast wheel. Lance (stroke of luck) has the same turbo but without the batmowheel and has no issues...
MINK
London,OH
Sadly I really dont see the cast wheel being the answer to your problems. Good luck though man.
INFAMOUS
Denver Colorado
Precision CEA FTW!
SEABEE08FX4
Montgomery TX
Thats crazy, I wonder why it won't build any boost. Your running 190/100's or 190/75's ?
No exhaust leaks ? No boost leaks ? That turbo seems to run well on other trucks such as Lances. Not knocking the injector builder but maybe it has a bad one, mistakes happen. Has there been any data logging or a balance test done ?
MINK
London,OH
Exactly, Jake Kelly's truck rips with 205s and the 68....Yours shouldnt be overfuled - atleast not to the extent that it sounds..
faster6.0
In the Brig (Banned)
it builds backpressure lol and runs smooth, if it builds back pressure its on the turbo to make boost.....
PTSUPERD
No exhaust leaks no boost leaks that we can find....plus I think if it could be manipulated into making 30 psi, there wouldnt be a leak at that level.
Regardless...Matt wants me to drive it as is so I can marvel at his mad skills. LOL He's happy with what he got out of it even with the issue.
PTSUPERD
Forgot to add. Jason ran a balance test on the injectors when the truck was done. They tested out fine.
PTSUPERD
Yes - if that does solve this then great.
I think there is only one other guy running a batmo that I'm aware of with this turbo....and I can't find any reviews.
From what I have seen feedback wise on the rcd 68...everything is good. All reviews have been with the cast wheel.
faster6.0
Honestly the ported manifold may show a decrease in overal boost because of less restriction, as long as it translates to more power to the ground.
