Excessive Blowby Ideas??
NRHX2009
Elizabethville, PA
How do you drive the thing? Is this a church and back truck?
Matt, Its a pulling truck and some street driving. On the way back from town, i only made 1 50psi pull in 4th to 5th gear. The truck has been very sluggish lately, super slow turbo spool up 28-2900 rpm. S476x 88 t6 1.10.
It used to be lit around 2500 . No exhaust or up pipe leaks either.
PSDEng
Bellefonte, PA
Yikes on the blowby :eek:
I'd check your compression numbers if you can....my guess is you're going to be less than pleased with them.
NRHX2009
Elizabethville, PA
thats the plan for this week, get some numbers to i know where to be looking when the motor comes out. I talked to Jason over at Carsons and that what he recommended i do first.
PSDEng
Bellefonte, PA
Did Carson build the motor for you? The reason I ask is because I think I may recognize the truck.
neverkickn
AR
Why bother with compression numbers? Just get it out and on a stand. Unless I am mistaken, the only thing that can cause that is piston, ring or cylinder wall damage.
