random no start.
lsmith33
Katy, TX
pulled one of my batterys out night b4 last to charge put it back in an now it wont start. no wait to start light. pulled my di chip off it starts but runs rough bc of the injectors i have......any ideas??? thanks
Big Bore
9000ft in the CO Rockies
Check all battery connections. Do not install or remove chip with key in ignition. As I learned the hard way, key in, but in off position, still energizes the pcm. If truck runs without chip, but won't run with chip, thats more than likely your problem. Do you get WTS when chip is out and it starts?
lsmith33
Katy, TX
chip in no wts, chip out wts an it starts put runs like sh!t. i understand how to install the chip but i didnt do anything regarding the chip. jus pulled a battery an put back in. ive had the chip in an had zero problems out of it since i bought it.
Big Bore
Like you said, it's the injectors. If you are running singles on a stock PCM...
Still sounds like the chip. Might wanna send it to David and have him take a look. It happens.
lsmith33
Katy, TX
ok cool luckily i work bout a block from di so i'll be calling him first thing in the morning. i jus was clueless when i put the battery back in an it would not start then i noticed there wasnt a wts light.
