Lifted 6.7's
03f3507.3
Hopefully ill have pics up of the dually tonight. Put a 2.5 inch leveling kit on it last weekend getting dual stabalizers, a 4inch rear block, and 34/11.5's today!
03f3507.3
2.5 inch ready lift, 3inch rear block( going to go with a 4 just needa pick up longer ubolts)
Chris1976
WV
Looks good like it is 03f3507.3 but the 4" spacer will look better. I like a little rake.
03f3507.3
Yeah we tried to do the 4inch block but since My truck has the camper package with the overload springs the ubolts were about an inch short. So I had to order longer ubolts. Ill get updated pics when we change it out.
Manytoys
Fort Saskatchwean, AB
Is it a 3inch block total or an additional 3 inch block with the stock one? What size tires do you have? I just traded my white 11 F450 for a black 12 F450 and am looking to lift/level it and am having tough time finding a kit that will work!
03f3507.3
3inch total, truck had factory 2inch and when leveled sat low in rear. 3 has it close but going with the 4 to give it a slight rake so its close to level with towing. Tires are 34/11.5/17 wanted to go 35/12.5 but didnt want the center of the tire to have an extreme creast to it.
Manytoys
Are you running spacers on the duals? Your truck stance is exactly what I'm after, looks great!
Manytoys
Does anybody foresee problems with me putting the readylift 3 1/2" leveling kit on my 450? It will raise front 3 1/2" and the rear 3". Truck has a factory 2" block and the leveling kit comes with a 5" block. The stance will be okay for me but will I have axle wrap or wheel hop issues, and if so what is the census on a solution?
TXGLASSMAN
Keller Texas
one up traction bars are the way to go. I love mine and will buy another set for the next rig for sure.
look and see if you can buy the traction block set up from OUO and buy the ready lift or any lift you want with out rear blocks
SAK
Victoria, Texas
OUO does not make traction block set up for the 450, but they do make a bolt on traction bar set up.
I would do the OUO bars with an ICON 2.5" system. You will like the way it rides over the Ready lift set up/
Manytoys
Thanks for the advice guys, I will look into those parts and keep you updated. I'm kinda already committed to the readylift kit but we will see what happens!
Emery19
Mount Laurel, NJ
pretty sure thats what he means.
also, woulda left it at 8 and put it on 37's with different rims.. and not do what he did in the third picture
