Low cylinder compression
tireman3
South Carolina
I recently did headstuds, new oil cooler, egr delete with the cab off (06 F250). After i got everything back together and cab back down, went to crank truck and had a loud banging from driver side. Pulled Valve cover off and rocker arm on #4 had broken(plastic clip failed). I installed new rocker arm and pushrod. Cranked up and no more banging but #4 injector was inop. Towed it to local Ford dealer and he ran test and suggusted we try an Injector, which made sense. After injector compression on #4 is at 18% i believe. Ford tech is suggesting maybe it was something in the head job that was done. Heads were checked and decked by a very good machine shop. Any suggestions or ideas of what to do from here?
DEEZUZ
NO PUKESTERS
NWI
plastic clip only keeps the rocker on long enough until fulcrum is torqued, has nothing to do while rocker is under tension of pushrod and valve bridge. chances are you didnt have the pushrod lined up correct and you smacked valve with piston....
kyle43335
In the Brig (Banned)
so could it be a possibility that the head was shaved to much?
being that you have a broken rocker/ bent push rod, i would say ctc is on track with a bent valve.
but i have seen first hand, how those "machine shops" that know so much, *** the pooch royally on machine work in general.
its anyones guess right now. the head has to come back off, and the valve on that cylinder must be inspected.
there are ways to test to see whats wrong. but i doubt you have the equipment to do that.
tireman3
South Carolina
Just to clarify the rocker arm did not break, the plastic clip broke and the push rod was not bent. I just replaced both to be on the safe side.
blackie375
remove rockers on that cyl,put air in cylinder and you should find out what valve it is
907DAVE
AK
Lesson learned, always bar an engine over by hand before buttoning it up.
Snoop
St Charles, IL
True that. Was just thinking of how much it's a pain in the ass when I pull the motor (instead of pulling cab) to do head work, but I'm forced to spin the motor to bolt up the TC. Spin it by hand to make sure everything is golden.
tireman3
South Carolina
Lesson was learned the hard way! I'm towing it today to a former ford tech to take a look at it and fix it for me. Will update what it was
tireman3
South Carolina
ended up being 2 bent exhaust valves on #4. Had them replaced. Trying to locate 3 headstuds and bolts right now and she will be ready to crank again.
