05 axles and conversion parts
Status
Not open for further replies.
rpm-inc
Matching set of 05 axles. Low mileage, was told they had 35k when I got them. Factory paint in good shape. Complete with brakes. Rear axle has one leaf spring pad cut off, I have another to weld on.
Also have coil buckets, front springs, track bar bracket, and radius arms. I do not have a track bar, rear springs, or radius arm frame brackets.
1650 picked up at 60185. Do not want to separate at this time. I do have an extra track bar mount if anyone needs only that.
OldschoolPSD
Central VA
I'm almost certain I won't like the answer, but where is it located?
Edit: took the initiative to google it, lots of freight headed in and out of the Chicago area so we might could do something. PM sent
FrankTheTank
Cecil County, MD
There is a rolling chassis in MD for sale right now for 1000 bucks in westminster.
Anyone who needs a track bar, i have one i can ship to ya.
NEVRNF
NW IL
Damit, Where was this in December. Right down the block from me to boot.
rpm-inc
1800 with a set of factory 18" wheels and decent tires.
rpm-inc
rpm-inc
I will try to get some pics of the axles themselves later today
rpm-inc
Back up for sale. Will just keep the factory axles in my obs if these sell.
1800 with wheels and tires.
rpm-inc
Do yourself a favor and do the conversion on your OBS, best non power mod you will ever do.
Damn it!!! I change my mind every few days, thought my mind was made up, and then you say this....
You got the 05 track bar bracket to work, correct? What did you have to do to do that.
FrankTheTank
Cecil County, MD
U just have to make a custom braket to fir your needs. If u buy a pre-made one it never seems to get the angles just right. If i were to do another id make my braket custom
Powerstroke Racer
Brenham TX
Ya the factory one worked just fine, call me at the shop when you get to that point.
I will get it up on the rack and get some better detailed pics for you.
rpm-inc
Awesome, I will do that!! Thanks.
So I am going to be putting 05 axles in the obs. Been looking for radius arm frame mounts forever, and ended up buying a complete rolling frame. So I will still have a set of axles, radius arms, buckets, front coils, track bar mount, and 17" aluminum wheels with tires that hold for sale next week.
I want this stuff gone fast after I get the rolling frame home. 1400
Status
