intercooler choice
cowboy420smoker
garberville ca
I was wondering which intercooler is a beter product.I have a choice between a bd or banks.The banks comes with boots and pipes plus hardware.
newman
paradise
I've seen a cut away of a BD and it looked like a quality product. I would but it over a Banks.
TARM
I have a hypermax coming to me. Go a great deal as normal retail price would be too hard a pill to swallow even given the performance.
Fl Stroker
get the 6.0 Banks ( $800.00)and order just the 7.3l pipes if you want($125). Then go to dieselpowerproducts and order the 3.5" to 3" hose and clamps ( $100.)to hook up the pipes to the intercooler.
that bag of hardware for the 7.3 from banks is like $325. and you don't need it with the 6.0 cooler which is bigger.
that is close to wholesale for the bank parts.
TARM
I believe with a small amount of work one of those big 6.7 Cummins intercoolers will fit and you should be able to pick those up in salvage yards cheaper than all the others less the 6.0. I woudl think it would offer very good perf but have not run one personally.
TARM
I know for the money there are so many better things to spend it on but excluding that, looking only at their effect on things such as pressure drop, temp drop of charged air, changes to egts, are there or are there not positive effects between running a stock IC versus Hypermax, Spearco, Banks, Hellman etc..
If you are running heavy NOS I would think its cooling effects would mitigate some of the performance a IC provided compared to fuel only but I certianly could be wrong on that as well.
Its hard to believe the performance of a 13 year old intercooler designed for 200HP worth of air flow could not and would not have been improved upon. Understand I am not saying one way or another it is or not you woudl just think like most everything else dealing with these motors there woudl be significant room for improvement.
I was looking back but could not find just yet the threads back over on TDS, before PSN etc.., where a few got together to run tests on the big 3 or 4 back then off one engine. Think it was back in 2006. Anyone recall those?
V-Ref
9 miles high @ 550 mph
Absolute waste of money:shrug:
:whs:
Still running a stocker here
You fellas run some really strong trucks....do you have before/after data that led you to this conclusion...or is it a case of you made a bunch of power on the stocker, and didn't see the need to spend the cash on a aftermarket IC. No agenda here other than to learn.
