1995 cclb restoration and build
swamp_ratt
hudson, wi
Sent from my EVO using Tapatalk! Snootchie Bootchies
swamp_ratt
hudson, wi
The body will be the original blue metallic that the obs was offered in.
Well, working my way around the cab with a flat head screw driver i found out above the windshield on the passenger side is rotted out so i need to replace that now too. Still not bad for a salt bowl truck all its life. That little spot and the driver side rocker is all that needs replacing on the cab
swamp_ratt
hudson, wi
Most of the cab floor herculined!
Sent from my EVO using Tapatalk! Snootchies Bootchies
swamp_ratt
hudson, wi
Another
swamp_ratt
hudson, wi
kinda thinkin keepin it flat black. Cheap and if i screw it up somehow its quick and easy to fix
MAC
Richmond, IN
I'd go this rout.
Not sure how a blue truck with a red frame would look.
swamp_ratt
hudson, wi
heres with 36 inch humvee tires on 16.5x12s and with a fender for mock up. Them 36s look small. Yes its stock height
swamp_ratt
hudson, wi
The cab painted and starting to go back together... But my dumba55 cant find half the bolts and screws!
Sent from my EVO using Tapatalk at work! Snootchie Bootchies
swamp_ratt
hudson, wi
Went to the junkyard today and got all the stuff off a t444e to put the ally 6 behind my 7.3 for 40 bucks. Check out my how to in my sig!
mudslinger02
MN
:nopics: Lets see some pics of the junk yard parts!! Even tho I was there I still want to see them again LOL
swamp_ratt
hudson, wi
Mockin up a gta4202
Sent from my EVO using Tapatalk! Snoothie Bootchies
swamp_ratt
hudson, wi
No... For the supercrew you are thinking about the 01 and newer crew cab half tons. Super duties are reg cab, extended cab and crew cab
Powerstroke Cowboy
Montana
Form the Pictures, It looks like you will have clearance issues were the turbo is sitting. The Turbo air intake and Plenum's look like they are in the place..
Maybe I cant see right on the pictures... But that is what it looks like.
DcMoore
Amarillo, Tx
Maybe I missed it but I thought you were putting a Cummins in it... And how the heck are you going to make the DP with out it being crushed?
swamp_ratt
hudson, wi
I have to modify the firewall and floor pan to get the allison in any way so ill cover the downpipe then too
