Rigging up a Tow bar
Trav-O
TN/KY Line
I need to rig up a tow bar to pull a F450. Anyone made one (with pics)?
Sure any for F250 to F550 will work the same
Trav-O
TN/KY Line
Well, I didn't get any help on figuring it out but I got one rigged up and towed a F450 210 miles.
Switched to a long hitch
TurboM700
Minnesota
How did it pull? Anything you would do different if you had todo it again?
I looked at a 08 truck that was 1000 miles away and thought about towing it the same way. Ended up not buying it but still was wondering if it would have worked.
loboost
Nice use of a tie wrap Lol
I might would add one more cross brace closer to the tongue but it looks good other than.
How's this play into actually being 'legal'? I'm interested in building something very very similar
sent while driving recklessly
Trav-O
TN/KY Line
It really sucked. But, I know I could of fixed it.
The drawbar is sleeved and has 2" side to side movement. Wasn't a good idea. Think that would of fixed most of my issues. And adding weight in the back of my truck would of helped.
TurboM700
Minnesota
Thought I would add a little update to this thread. I had to tow a X home yesterday with a blown motor. 90 total miles and it pulled way nicer then I would have thought. Heck I think it pulled better then being on a trailer. I was actually able to back it up my drive way thru my garage and into my back yard.
Here is my tow bar that I fab up sunday morning. Tried rigging up lights but i wasnt able to back feed into the X lights thru the trailer plug.
TurboM700
Minnesota
Yup and it will follow right behind you like a lost puppy dog.
I was actually able to back it up by drive way and thru my garage without any issues.
capt dong
Houston, TX
Excellent thread. Thanks for sharing. Need to build a tow bar to pull a f350 drw. How did you hook up the tow bar to the excursion?
dsberman94
Pennsylvania
He welded two plates to the tubing, one on top and one on bottom the the front tow eye on the X. Them used a grade 8 bolt through the tow eye and both plates.
