Is this the T4 .83 turbine housing everyone raves about?
MorganY
college station, tx
Hellen Keller sent this?
Yup, mine is just like that.
MorganY
college station, tx
where did your housing come from if you don't mind me asking?
Jake @ Irate. Was quick and on the money.
Jose kept giving me the run around for 3 months with a big order I placed through him for someone else. Can't deal with him anymore.
ATP has my business for turbos now. They don't mess around.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
Extended Power
I had to get custom adapters/spacer made up to make up the 2+" difference in length from a internally gated T3 housing, to this T4 housing.
Hope it flows better than the T3 x .70 housing.
But hope its not as laggy as when I tried a T3 x .80 housing with internal gate. The .70 has so much quicker response, I was only able to put 50 miles on with the .80, and I yanked it off.
More gate!!!!
Extended Power
Here's some pictures of the adaptor.
This end lines up the HX40 flanges.
This is the end that fits inside the housing, and seals up against the marmon flange.
The adaptor will center the exhaust flanges, and hopefully have a zero leak-ever again!
Powerstroke Cowboy
Montana
I agree there are a LOT of different styles out there. Its hard to keep up with them all. This is a .83 A/R housing made for the 68mm turbine wheel. Its a Genuine Borg Warner housing.
FaSSt9602
Gilbert, AZ
Before the FMW unit, a 68 housing needed to be machined correct?
I'll have to get mine out and take a look at it, but I don't remember such a long snout on mine.
Powerstroke Cowboy
Montana
Correct. That's a 179069, comes on the 62/68 FMW
I am preety sure that is not the part number that is stamped on the housing.
I can check But almost 100% sure that is not it. The part number start with a 6 and ends with a 8 I will have to check.
Extended Power
Here is a comparison between the T3 .70 housing on the right, and the T4 .83 housing on the left.
Extended Power
Yeah i definitely wouldnt put that on, not worth the time LOL
Why?
Since when can a person tell how a housing will work just by looking at it?
One is taller and longer because it has an internal gate.
The other is a straight divided housing, no extra bullschit attached.
JDub
Hooper, Utah
That number on the side isn't always a part number. May just be a casting number.
NRHX2009
Elizabethville, PA
If I am not mistaken, there is a .83 T4 S200 turbine housing as well. Doesn't explain the different port size, but could explain the variance in housing look from the exterior view.
