Substantial oil leak
Six_Sloww
Southeast MI
Just the other day I seem to have developed a pretty major oil leak..
It seems to be coming from somewhere on top of the transmission then dripping down both sides, if the truck isn't running it'll leave 2 large puddles of oil, and eventually stop dripping
This is a pic I snapped after the truck was sitting for 4 hours.
Is there anything common that leaks on the back side of the motor that I should be looking for? My first assumption is oil drain off of the turbos, but I'm new to the 6.4 game.
Six_Sloww
Southeast MI
Broke down and crawled under. It's definitely coming from up in the turbo area and dripping onto the top of the bellhousing, tough to say exactly... There's oil everywhere
Six_Sloww
Southeast MI
Wouldn't I feel a miss? It's running fine with no smoke or anything, just oil
No Cel btw
Sideswipe505
New Mexico
No CEL means nothing on these motors. Guys drive around on cracked pistons and never know til it really lets go.
Sent from my HTC6435LVW using Tapatalk
webb06
Seneca, MO
If the glowplug harness were pushed out the truck would definitely have a miss to it, he's refer to a cracked piston situation. I would lean more towards either turbo drain o-rings leaking under the high pressure turbo or the little rubber standpipe under the low pressure being split.
Clean the turbo area with stating fluid and get a good flashlight and a mirror and poke around to see if you can find it. Might need to have it running while checking
Six_Sloww
Southeast MI
Is there a reason why you use starting fluid? As opposed to let's say brake clean?
There's definitely a bunch of oil in the valley of the motor, is there anything else that would be leaking this much from there?
The amount of oil that leaks seems to be inconsistent.
webb06
Seneca, MO
Either or. Brake clean will eat off paint and my engine is paint so.
Heres a truck we had come in with the turbo drain o ring leaking badly
webb06
Seneca, MO
With a light and mirror you should be able to find the source pretty easily with it running
pooter
marietta,ohio
I cut my downpipe in half and it came out I removed the pass side inner fender and it was easy to get to that way. my new down pipe was two piece and it fell right in to place I used a flo-pro exhaust btw
Six_Sloww
Southeast MI
Welp.. It appears that the oil was overfilled due to excessive regen. I changed my oil last weekend and it's not leaking anymore.
Dpf is coming off this weekend!
MrMike2010
Long Island, NY
If it was over full that means u are dumping fuel into the oil. Fuel isn't a very good lubercant. I suggest delete that bad boy before u start having some major issues.
RedRice589
Ocala, Florida
Came in yesterday, it's actually in great shape for a used exhaust pipe.. No way in hell I could buy something secondhand like that up here.
Thanks again
Lol that was on the truck in '08 when he bought it! The build date was 12/06 and he bought it in June '07. Gotta love Florida.
