01 7.3 no start
WILD_PHIL
East TX
Wish it was that easy.
E99 F350/zf6/guages/arp/comp/stellite/ billet wheel/ bellowed... Need more fuel and more air.
WILD_PHIL
East TX
Another buddy suggested the solenoid on the starter.
pdumont01
CT
If it was the one on the starter jumping the solenoid on the pass fender would not do anything. Maybe ignition switch bad ?
WILD_PHIL
East TX
I thought the same thing. But was told I was wrong. I have considered the ignition switch but I'm not sure how to check it. Someone suggested hooking a test light to the fender solenoid and hitting the ignition.
pdumont01
CT
Hook test lite to ground and the small wire that slides onto the solenoid have someone turn the key the light should light up. If it does not no signal is coming from the switch. It could be the wire, the switch, or the neutral safety system. Assuming you checked all the fuses ;-)
WILD_PHIL
East TX
Ok. I'll let yall know.
