02 abs light on
Stout7.3
Okay so about a month or 2 ago I changed the driver side hub and wheel bearing since my old one was really bad and when I got all done I went to drive it and my abs light is on. Sometimes when I drive it the light doesn't come on but most of the times it does. Any thoughts?
Stout7.3
I checked the other hub and it seems and sounds fine. Same with the vss. I took it out and cleaned it and it's still doing it
dsberman94
Pennsylvania
The abs sensors in the bearing assembly gets junk on it and won't read sometimes as they get older. Or you've got a bad sensor on that new hub.
ToMang07
Mainah!
Get it scanned with AE or similar good scanner than can connect to ABS, find out which sensor it is.
