fordboy11
Like the title says the true started running rough a few month ago. Unhook the battery's and it will run normal for about 20 miles. Since then it got a new fuel pump and all new injectors and stand pipes. At idle it's 630-670 oil pressure. I unplugged the icp sensor but still idles fine but buck and the tach jump up and down from 550-1200 as well with oil pressure jumps around. A little help please and thank you.
