04 6.0 Bad PCM?
msheffield
My truck shut off while sitting in park idling. It shut off as if I turned the ignition off. I got to restart the truck and...nothing. Not a sound, not even a peep. My fuel pump did not energize nor did my injectors buzz. Just nothing. Although, my gauges lit up. My batteries are good, the connection is fine. I checked every fuse and relay for continuity and resistance. Here's the kicker, OBD II has power but will not communicate with my scanner. Not really sure what to try next. I can't find a PCM pin diagram anywhere to attempt to troubleshoot the connectors.
Sent from my SM-N910T using Tapatalk
msheffield
Probably a PCM.. I had this identical issue in my old 6.4L and it turned out being the smart junction box which is basically the 6.4Ls version of the PCM I believe.
Thank you. That's all that I can imagine it to be...
