So I swapped out my rear-end for a 2014 axle with 4.30 gears. I didn't think about a couple things prior to swapping over.
How does a 2014 read speed? I am without a speedometer currently.
Which connection on the 14 axle would be for the electric locker? The green plug is the one that I am unsure what it is. If you pop this connector of it appears wires are going inside the differential. The service tag is missing on the axle.
