05 front and rear axle on the frame
Faste
Bought this frame to convert my 01 to coil spring. Now I have other projects popped up if anyone else would like to use it. I give $1000 for it will consider engine upgrades for trade. Alabama gulf area
thoroughbredcont
What gears are in these axles
2000 excursion: FF350/200, BTS twins,BTS trans, 468 turbo, Irate fuel system , DI rr, 910's shimmed, swamps IDM , hydra , ******** tunes
Faste
3:73 gears, no I'm not parting it out. If no one needs it I'll eventually get around to putting them under my truck
Faste
I believe it was extended cab, I was told frame is bent, I got the whole thing just to make the swap easier. Wasn't planning on using the frame
