Jeremyleggett07
I am thinking of putting my 2005 heated/lighted mirrors on my fathers 2001, and buy myself some 08+ mirrors. Is there an adapter needed to have lights work for it? Just a thought thanks guys!
i did this already, as well.
there are a few things you will need to know.
wiring is as vader said. the plug that is in your door, will not work. if you want to maintain plug and play. you will need to change the door side plug, to the 05+ as well. this lets you tie in all your wires into a existing plug. otherwise you will have to cut the plug off the new mirror to wire them up.
i went to car-part.com and got both door plugs sent to me for $15 shipped.
if i break a mirror, its just plug and play.
your wiring, if you have power, will go into the new plug, then you just add whatever additional functions you get with your new mirrors.
i went from just power, to power/heat/turn. i needed to run two wires. for the heat, and the turn, and a switch to control the heat.
and they will just bolt on. its the same pattern, same everything, but the couple additional wires.
it should also be noted, if you get power fold, and power telescope, you will need the 08+ switches that have this function, as you cannot make them work with out them. and i played with them for a while trying to figure out how to do it.
