08+ door panels,mirrors, and plastics in a 06 f350
Whitezotti
helotes texas
I am also planning on running power to the center console to get the power points working or cigarette lighter. There's 2 separate ones. One for the back and one in the console.
darkdragoon09
You have the patterns for the 2003 and 2009 side view mirrors connectors? I just want to upgrade side view mirrors. My side view mirror have the features heated, electric, signal and manual folding. I want to upgrade for model 2009 with same features.
Whitezotti
helotes texas
08 door wire diagram
http://powerstrokearmy.com/photopost/data/500/medium/image243.jpg
pfm relay (power fold)
http://powerstrokearmy.com/photopost/data/500/medium/image226.jpg
http://powerstrokearmy.com/photopost/data/500/medium/image227.jpg
http://powerstrokearmy.com/photopost/data/500/medium/image228.jpg
08 front door grab handles and pillar
http://powerstrokearmy.com/photopost/data/500/medium/image230.jpg
08 door handles
http://powerstrokearmy.com/photopost/data/500/medium/image231.jpg
08 rear door grab handles. these do not sit on a pillar. they sit on the head liner
http://powerstrokearmy.com/photopost/data/500/medium/image242.jpg
08 bucket seat trim and seat control cover.
http://powerstrokearmy.com/photopost/data/500/medium/image232.jpg
08 door sill.
http://powerstrokearmy.com/photopost/data/500/medium/image233.jpg
08 rear door with tweeter
http://powerstrokearmy.com/photopost/data/500/medium/image234.jpg
08 mirror control (part of 08 door wire harness) and connection to mirror. Mirror connector is for power everything except memory. (first picture)top plug is for all mirror controls and mirror foldin and out. middle plug is for mirror extend in and out. last plug connects to mirror.
http://powerstrokearmy.com/photopost/data/500/medium/image235.jpg
http://powerstrokearmy.com/photopost/data/500/medium/image241.jpg
08 window and door lock controls (part of 08 door wire harness) little black and white plug is for door locks. rest is for windows
mirror plug. from mirror side. 11 wires for power extend, power fold, power adjust, heat and it does not have memory. memory should have 16 wires
http://powerstrokearmy.com/photopost/data/500/medium/image238.jpg
http://powerstrokearmy.com/photopost/data/500/medium/image239.jpg
http://powerstrokearmy.com/photopost/data/500/medium/image240.jpg
http://powerstrokearmy.com/photopost/data/500/medium/image236.jpg
darkdragoon09
I'll look for you bro the 2009 should definatlety be the same as 08
Yeah I know 2008+ should be same wire configuration. I want to know what function do each color in the 2008+ side view mirror and in my side view mirror conector to adapt each feature to my plug. I dont want more features the my side view mirror have(I almost have all). My side view miror are electric, heated, signal/maker light, manual folding and manual telescoping. I want same sde view mirror but model 2008+. That why I'm looking for ping configuration worst case I cut the cables from my old side vire mirror to adapt them to the new 2008+ model and have same plug.
Whitezotti
helotes texas
That's what I'm going to do if this plug doesn't work. Hopefully the pinout it's the same. If it's easy to change I will if not I'll just cut and splice :(. I just want it as factory as possible. If I ever sell it in the future and it holds up a lot more if it's like that. It looks professional is what I'm going for. Id do the dash if I had enough expirence.
Whitezotti
helotes texas
I'm talking about my pin config. For my door wire assembly not the mirrors. Because if that door wire assembly works and the pin out works . Everything will work in the door. And I won't have to splice anything . Except the Pfm relay harness. Which everyone has to. That's the only thing I'm not to familiar how to do it. And where to slice it at.
co04cobra
WV
You got lucky on your 06 having a separate door harness. It wasn't until late 06 ford started the plug at the door jamb.
I also believe you are going to run into the 08 mirrors working backwards of your switch.
Whitezotti
helotes texas
FYI bro the 2003 has a different plug for the door wire harness it's not the same as a 08 or 06. Sorry . But I'm pretty sure about that to.
And yea man I did get lucky whoo
Whitezotti
helotes texas
You mean the mirror adjust ment or the extend or fold. I know I gotta do the Pfm . But I think hour saying about the mirror adjustments.
Whitezotti
helotes texas
Has anyone exchanged the green light inside the door switches and dash and speedo? To put new LEDs or a different light in?
Whitezotti
helotes texas
On the front door grab handle and pillar. If the new handle does not fit where the pillar is originally on my truck. I will replace the whole pillar for both sides. That's why I purchased both. Just so y'all know why I wasted more money on ebay. Lol I will post more pictures of the complete product.
Second for the cover for the bucket seat controls. I'm going to see if I can exchange the cover on the original 06 seats. If it fits I will try and replace the switches and wiring. Therefore just the outter cover for now. If not I found someone selling auto seats for cheap on ebay. And I will ditch the seat since it's a different color and use just the seat rails and frame and connect it to my 06 seats. Then if it doesn't plug and play I will wire it. The only difference between the 08-10 seats is there is no lariat signature on the front buckets. Second. There is a line of stitching down the middle of the bottom cushion and the top head rest . Same for the front and back seats. I can live with my 06 seats without the middle stitching. It looks close enough. But if you wanna spend another couple grand then Re up popster it. Be my guest and do it. For 2000 grand I can live without the stitching. If you really wanted to you could go to a upolster that's really good and they can put that stitching in for you! And save tons of money. The only thing is they might have to replace the leather where the lariat writing is. But that's only two top seat covers on the bucket seats. I think ford did this to help sturdy the seat leather. Because the leather wears easy and separates. I've already had to buy two different drivers seat bottoms. Thankfully . It's only been those two and nothing else.
Whitezotti
helotes texas
On the 08 door handles I purchased I'm hoping to see if they fit in the new door panels . Which I've heard don't fit. Because the 08 panels stick out a little more. Therefore people put 1/2 inch of washers to push the handle out so the panel slides behind it. If this handle doesn't work. I will use the washer idea. I've also heard the handles are not as wide, from end to end. I will see when i try.
Whitezotti
helotes texas
Thanks a lot man :)
Hey if anyone in Texas wants to help me install these panels,mirrors, and plastics let me know. I'll pay for help. Make sure your semi experience. And if you are a good help or very experience (good electrician). I'll pay more. I'm in San Antonio. If you have to travel let me know the pay might be worth it to exspecially if your experienced. I also I have some suspension work I need to do replace rear shocks . Intact all a drop track bar bracket. Internal engine work. Most likely I can put that off till later. I'm able to do the suspension work but I need the help. Engine work kind of complicated and time consuming. I have a whole indoor shop. Plenty of tools and parts. Also have a lift, and crane. If anyone in Texas interested let me know. I also have a lot of 6.0 engine parts and interior and exterior parts. And 6.4 interior parts. Let me know I can trade those and make a good deal. Or pay cash. I also have 6.0 injector nozzles. I can work a good deal if you help me install the panels and interior stuff . Or if you do a lot of work I can trade them. I also have new sway bars to be replaced and rear ones that need to be installed. Replace a piece of exhaust . I have all the peices to do these jobs. Let me know if you want to help me. Any help is good help. If your semi experienced that's fine you can take pictures to post on Psa and help me. Just make sure you have some experience with interior work.
2000wa250
Out of curiosity, how much did all the pieces run you? Are you just doing the doors and everything?
Also, any idea if an 08 dash would fit on/in a 2000? I'm assuming no..
Whitezotti
helotes texas
Yea man a. 08 dash will. You just gotta re wire like hell. And you gotta install that crossmember that comes with the dash. And I think you need a new heater box that's under the passenger side. I think that's about it. You probably need to be a very good electrician. You prolly need a 08 fuse box. And a 08 dash harness . I've seen people do it all the time . It's just very hard. I wanted to do it. But it's way to difficult.
Door panels were the most expensive about 500 for all of them. I payed 350 for all four but the guy who sent them only sent me 3. He said ups stole them. I think he's full of ****. So we both made a complaint. So I had to buy 1 more rear panel. But the rear panel I bought had the tweeter built in. So I had to buy another rear panel for the other side with a tweeter built in . I actually changed my mind. I wanted to do the tweeters all around after I found out that guy screwed me.
Any way I got a good deal on all 4 for 300. And I bought two separate for 100 a piece so 500 total. And I still have a extra rear panel. But it has no tweeter.
Whitezotti
helotes texas
Everything I bought off ebay . Except the front sail panel tweeters . I couldn't find them. The door wire harness. I couldn't find the right one. I found the rear door wire harnesses tho. For 80$ for the pair ebay. All the pull and grab handles were about 130 total. With the pillar. On ebay. The mirrors I got from ford. I have a company discount because my family has an account with ford. So we get like 30 percent off. Still it was very expensive. You can find the aftermarket ones for half the price. But these do come with the Pfm relay for free. Which costs about 80$ for one on ebay.
Whitezotti
helotes texas
I'm doing the doors and all the plastics that changed in. 08. Except the dash and seats. But I'm doing the plastics on the seats if it's not to hard.
