1 issue fixed to find another issue....
MaDCoW40
Sooooo I fixed my DTC codes for the map and turbos which was caused by the EBP tube was completely clogged... used some brakeclean and a air compressor and cleaned the tube all out... replaced the sensor on top.... drove great.... baby turbo is actually building boost at low speeds like it should.... now... I hear a ssssssSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSS when driving.... the more gas I give the more and louder it gets.... raised the hood... had my dad rev it a few times... to see black exhaust smoke come from what seems to be driver side... nice clean EBP tube is now black... any ideas where the leak would be?
Mesa, AZ
Could be a broken up pipe, blown out gasket, broken bolts, etc. Is it coming from the top or bottom?
MaDCoW40
Looks like bottom. Soot over everything under it around the area where you screw the ebp pipe down. Well a little under it
MaDCoW40
The noise kind of sounds like if you shot a hose into the back of a running fan
Mesa, AZ
Check and make sure the tube is tight. And check the manifold for broken bolts or leaks.
