SAK
Had this behind the back seat of my 11, swapped it out for something different. Works just fine.
Specs are:
Power Handling
1500W Max
400W RMS
General Specifications
Frequency Response: 20 ~ 230Hz
Sensitivity: : 93db
Recommended Enclosure: 0.5 ~ 1.0 Cubic Feet
Dimensions: 13" x 3-7/8"
Mounting Depth: 3-1/4"
Accessory Grill: UD-G308
General Features
Interlaced Basalt/Carbon Fiber Reinforced IMPP ConeDouble Cone with Air Suspension Control System
3-Layer Fiber Woven Radial Surround with M-shape Cross-section
Aluminum 6 Layer, Long Voice Coils
Aluminum Voice Coil Wire
Phenol Resin Coated Glass Cloth Voice Coil Bobbin
Projected Pole Yoke with Vented Pole
Strontium Magnet ConstructionCast Aluminum Basket with Fin-Shaped Design Basket Design
Rubber Gasket
Silver Spring Compression Terminals
$100 plus the ride. I can bring this with me to Ennis this weekend.
Specs are:
Power Handling
1500W Max
400W RMS
Sensitivity: : 93db
General Features
Rubber Gasket
