12v into an obs questions
chappy
Marshall Mi
We used destroked in my buddies obs. He wanted to go to a manual also so he found a zf5 out of a superduty gasser with tcase for $400 on craigslist. He said the adapter was cheaper from destroked for that trans but I don't know. works great though
genuineford
Vesper, WI
Probably the best way to go in my opinion Steve. That way you've got just about everything you need except, engine mounts, and some plumbing!
Yeah I have been looking at prices and even if I spend 4K on a whole truck I think I will be money ahead. I have found a few in the 3K range so I will probably end up spending about that much.
Dave
Those of you that did a 12v swap into an obs, what engine mounts did you use. Any other parts I would need to get for the swap to work. I plan on using the dodge trans and transfer case. I will just modify or fabricate a new trans cross member. Anything I need to take into consideration. I have a feeling I will be doing one of these in the near future.
Somehow I knew the 460 wouldnt stay in the truck long:joy:
