19.5 wheels
stroker96
Central OH
Hey guys I have a 2014 F350 dually now, I was wondering what is have to do to put ford Alcoa 19.5 10 lug wheels on my truck?? (I have to buy tires now and found a good deal on 19.5 wheels and tires) I do a lot of hauling with it also if it makes any difference..
Endless
Need a set of adapter hubs from the Ford f450 front and back. I'd also go to the 450 brakes, they're more beef.. behind those factory adapters on a f450 sits the same 8x170 bolt pattern you currently have if you unbolt your adapters. I think you have 8x200 or 8x220 with your factory adapter on..
gnxtc2
Bergen County, NJ USA
Very interesting, makes the swap much easier...thanks for the info.
If you swap hub adapters, you're gonna need to swap over to F450 brakes...the rotors aren't going to fit.
Billy T.
[email protected]
Sportchassis06
American Force has DIRECT BOLT ON 19.5 wheels,no adapters.I know,I had them on my '11 F-350 dually
stroker96
Central OH
I seen those, but those are out of budget for me. I just found a deal on Alcoa 19.5's with new tires pretty cheap is the only reason I was curious... I'd much rather direct bolt on though....
