-19 or -24 offset
13farm
Looking for some opinions on wheels or pics of people that have something close to this. How far will a -19 offset stick out on a 2013. How far will a -24 stick out. These will be going on a stock truck with a 20x10 wheel with a 33in tire so will any trimming have to be done? Looking for side shots of vehicles to see how much they stick out. There are so many pictures on here but hardly anybody post straight on side shots.
why not search thru the bajillion threads that discuss the same thing?!?
this place is turning into the morg...smh
13farm
I searched thru 101 pages of the leveled truck thred and pretty much everyone is running a 20x12 and if there not they are running a 20x10 and with a 37x13 or all they want to show is a side picture of the truck. Not everyone has 5-7 grand to spend on wheels tires and a lift to clear 20x12. So unless you can show me a pic directly down the side of a 20x10 wheel and tire set up....all I was asking was a simple question of how many inches they stick out on diffrent offsets.
kevin1106
La Plata MD
Here ya go
I have 22x10 with a 24mm offset, I also have buschwacker fender flares install.. My wheels sit flush with the flares... I have 325/50/22 MT tires.. I only had to trim my driver side bumper bracket a little. Very very minor.. If you are running 33's , I don't think you'll have any issues with rubbing
13farm
Thanks for the help rather than a useless comment....good looking truck just curious what size lift?
kevin1106
La Plata MD
No problem...... Lift kit, I used Icon 4.5 stage one... This kit made the truck sit higher in the front than the back, by 1in...also the rear wheel was no longer centered in the fender well, So I purchased ouo 7in traction block with traction bars... Now my truck sits 1in higher in the back and the wheels are now centered in the wells. Thinking of adding a 1in spacer to the front... But haven't made up my mind.
Bryan55
Jacksonville, Florida
2016 with 2.5" leveling kit in front and stock blocks in rear. 20 x 10 -24 fuel mavericks with 35" x12.50 toyo MT's. I had to cut the bumper brackets on both sides and cut the felt stuff with a razor blade on the back part of the wheel well. Not to bad and these are on 35" so the 33" I would think would be fine!
BSB
I've got that exact setup 20x10 -24 on a 2012 with 305/55/20 duratracs good amount of poke rubs a little on my mudflap with a level. Don't have any pics on my computer but if you're on instagram I have some on my page blacksmokebullies
