1995 F-350 Overhaul
Beau
Buffalo, MN
It should be somewhere in there. I'm only going to run a 400/200 injector. Still have to pull a trailer around.
Beau
Buffalo, MN
Haven't updated this for a while, I have been busy fitting the engine into the fire wall, lets just say that it required alot of plasma cutting, and welding up my new fire wall. I fit the heater box and A/C box, had to modify both to fit, but it will work. A/C will be a retro fit on this truck since it was a XL. Cut my thumb bad doing this and now it dont work so good any more. Cab is stripped and working on putting the Sunroof in, and repair panels. all most everything should fit under the stock hood which will be nice. Have to figure put an air box design......? IT's f-in cold out but its MN, work is moving a bit slower.
Beau
Buffalo, MN
I built it, 45 gallon, with sump, 14 gauge mild steel, not much else, what else you would you like to know?
Beau
Buffalo, MN
Not a whole lot to update on. I have a new box and gate headed here from Arizona, I got a new radiator core, only to hack it all apart to make it work with the bigger radiator, New tires, My body man isnt doing anything so nothing to update there. Im going to pull the motor and trans and paint it this weekend, about it.
http://powerstrokearmy.com/photopost/data/500/medium/radcore.jpg
http://powerstrokearmy.com/photopost/data/500/medium/tire2.jpg
http://powerstrokearmy.com/photopost/data/500/medium/tire.jpg
Beau
Buffalo, MN
I have restricters in all the turbo feeds. They all are ball bearing units. 66 and 82 from turbonetics. And a 94 from percision. I will put a gauge on the engine during break-in to make sure oil pressure doesn't fall below 15 psi. If it drops I will add the hv pump to it. I bought the melling so I'll give it a shot.
