1995 F250 ECLB $7500obo
94.5 Stroker
Lincoln, Nebraska
1995 F250 ECLB XLT, 5spd 4x4 224k miles. Front brakes were done last year and rear were done about three weeks ago with new master, wheel cylinders, shoes, hardware, drums, and rear ebrake cables. It has Full Force Stg 1 injectors, Stealth SRP1, TS 6 pos. with gearhead tunes, SD intercooler, E99 spyder, and custom pipes, 5 inch tb with a 7 inch tip. It has Glowshift boost and pyro gauges on the pillar.2008 Super Duty diff cover installed a couple thousand miles ago. All of this has about 10-12k miles on it and at that time it also got a new timing cover and Luk clutch. It does have some rust but not to bad, has to five inch holes in the front corners from the previous owner installing stacks the wrong way, and a small leak from the tcase front output. Does need tires, currently running 315/75r16, was on the truck when I bought it, I believe it has two add-a-leafs in the front packs. I would drive this truck anywhere with no worries. $7500obo PM, call or text 402-309-0974
