1997 F350- 7.3- 4x4- CLEAN! $14,500
Derek@Vision Diesel
Canby, OR
It is actually a F250, but was straight axle swapped so is essentially now an f350.
97 Ford F-350 XLT 4x4 7.3 Powerstroke. Odometer has 267xxx miles , but i swapped another motor in with only 100K on it. Runs strong I've put 7K miles on it and had no issues with the motor. Resealed the motor before install and cleaned up
Many upgrades and mods on the pickup, it dynoed 427HP and 790ft lbs torque in a street file designed for smoke control.
-Newer 38r turbo with under 5,000 miles on it
-New injectors from unlimited Diesel 250cc 200%Nozzles
-Fuel system from irate diesel.
-Regulated Return Fuel System
-T500 high pressure oil pump
-ARP head studs
-Swamps IDM
-Crank Case re-Route
-6637 Intake system
-Intercooler off a 6.0 with custom IC piping
-TS 6 pos chip with tunes from Power Hungry Performance
-John Woods Economy HD transmission- 3,000 miles on it
-3in down pipe to full 5in one piece exhaust with 6in tip
- Brand new motorcraft batteries
- Quad Pod with ISSPRO gauges (Trans temp, fuel pressure, EGT, Boost)
- Red head steering box with all motorcraft steering components
- 4.10 gears
- All new brakes
- RiffRaff Diesel rear differential cover
-Has airbags, gooseneck hitch, homemade traction bars.
-lifted 6" on Incubus wheels and 37" Nitto Mud Grapplers
-Has matching white canopy with new weatherstripping and fresh keys/locks
$14,500
