Power Strokes
94-97 Aftermarket
1997 Ford F250 Axle Swap
[QUOTE="Diesel_Brad, post: 1460678, member: 668"] Since You already own the 99 axle(BTW it is a dana 50 unless it is a dually) I would use it. You still need spring mounts to attach it to your truck. PMF makes the offset RSK to put in the front hanger(you will need to box your frame rails to install the RSK correctly). SKY manufacturing also makes an offset RSK and the hangers for the rear of the spring. The RSk will allow you to use the better ridding 99-04 longer lea springs(3-3/8" longer). But you will also want to get the rear SD axle as well since the SD has a metric 8 on 170mm bolt pattern. They also have disc brakes [/QUOTE]
Latest: gahm3r
Yesterday at 4:16 PM
6.4 Tech
Latest: 03f3507.3
Yesterday at 2:11 PM
Engine and Drivetrain
Latest: ToMang07
Yesterday at 7:28 AM
B
No Start help
Latest: bismic
Yesterday at 7:04 AM
Latest: 6.0 Tech
Wednesday at 8:24 AM
Ford Power Stroke News
Henrypoulk
Power Strokes
94-97 Aftermarket
