1999 CCLB 7.3
BigRed97
Saugus MA
1999 Ford F250, 7.3L Powerstroke. Crew Cab, 8ft bed 275k miles on engine
Base engine has 275k miles, all mods including BTS transmission are new within 15k miles.
Engine:
ARP Head studs, CompCams 910 valve springs, Smith Bros hardened push rods.
Swamps Diesel injectors 250cc/80% nozzles, Swamps High Frequency/ High voltage IDM.
Adrenaline HPOP
6637 air filter
T4i turbo mount kit with custom S366/71 turbo from Carson Stauffer Diesel.
4inch exhaust with FTE resonator.
Coolant bypass filter.
Heater core shut off valve for hot summer days
Custom tuning from Swamps Diesel with over-boost fooler.
Custom designed and built regulated return fuel system with in tank mods
Transmission:
BTS transmission w/extra fluid cooler and external filter setup.
Suspension:
05+ coil spring/radius arm front axle conversion with plow prep coils
3.5in front lift-coil spacers, drop brackets, dual steering stabilizers all from PMF Suspension.
Adjustable trac bar
5 inch rear traction block/bar setup from PMF suspension.
Fully adjustable carrier bearing mount from PMF suspension.
08+ rear spring conversion with mounts from PMF suspension.
Exterior:
Custom Orange pearl paint
Clear Bra lower protection full length of truck and on top of fenders
Custom fit 05 front grill
08+ side mirrors
NTO bed with 08+ tailgate and tail lights. LineX bed liner.
Back up camera.
08+ rear bumper
LED lighting with load equalizers
6K HID lighting in head and fog lights
Interior:
FULLY sound deadened with DynaMat,PhatMat, and 1/8 inch layer of dense closed cell foam.
Black interior conversion.
Weather tech floor liners.
Front captains chairs with 3rd seat from split bench
Custom Caltrends 2 tone seat covers.
Custom orange lighting in gauges and switches.
US Gauge cluster overlay
3 pod A-piller gauges- boost, trans temp, and EGT.
F650 lower dash panel with chip setting control and custom gauge setup- ICP press, fuel press, Oil Temp.
Ford Aux Idle Controler
Pioneer AppRadio2 touch screen.
Kenwood speakers
Tinted windows with rear privacy glass.
The truck needs rocker pannels repair/replaced. My original price has been dropped in consideration of this, now asking $13,500
The 20in wheels and tires have been swapped to the new truck and it now has brand new(less than 1k miles) chrome 18s and mich tires of the 2016
please feel free to ask any questions! thanks for looking!
$13,500
BigRed97
Saugus MA
pics
BigRed97
Saugus MA
more
11lifted250
When was most of the engine work done? Mileage on engine work?
Sent from my XT1565 using Tapatalk
BigRed97
Saugus MA
Rockers definitely need to be done, drivers is worse than passengers
No other rust, corners were done and bed was replaced
BigRed97
Saugus MA
Sorry for the delay
Chvyrkr
06 LBZ dually, 2wd.
Truck has had a Fleece 68 turbo installed since the dyno tune. Replaced the worn out fuel system at that time too. Maybe 15k on those.
Truck has 30% nozzles and a 50% pump, ARP's, Airdog, trans work (not built) etc.
280ish on chasis, <30k on engine. Chasis was repainted with the new engine. Trans was rebuilt with "billet converter" and unknown other parts at that time as well. Leather interior in new-ish condition.
