#2 Thread..What is your next planned modification Run off of TomS thread
TrailerHauler
Michigan
Should be getting a south bend dual disk clutch next week, then...
Probably 19.5" wheels
Fuel system/ regulated return
t4 mount
turbo
then probably,
Head studs
Valve springs
Bigger injectors
roustabout04
Jena, LA
Currently putting head studs, gaskets, EGR delete, new oil cooler, 175cc injectors, radiator, and 58v FICM.
Then after i save some more up itll be coolant filter, and new CAC boots.
TurdHerder7.3
Topeka, Kansas
Going to finish the sheetnetal on the 68 mustang coupe and start on the 331 stroker to drop in.
Just need to mod the garage first with proper power so I don't burn the place down welding with the previous owners wiring.
Diezel Dawg
Cheney, WA
Fuel system:
Regulated Return w/ Fuel Bowl Delete
Airdog II
Sump
Traction bars
HPOP-Termy
Future:
Head Studs
Springs
Freshen Up Injectors
El chupacabra
Erie, Pa
68mm rcd powermax , air dog II, 205 or 225 injectors, head studs sct with custom tunes, dually bed , ten lug wheel adaptors with some michelin x1 super singles on the rear those tires would look badass and wear like iron
Jeff@Spartan
Georgia
Elite 71mm modded atmosphere charger with a Precision billet wheel, Mike D's intake elbow and CAC pipe, replace #8 glow plug, replace fan clutch, fix electronic 4wd, finally install my Retro HID's, PTM door handles, white mirror caps, new cab light lenses and 3rd brake light, 20x9 chrome BMF Novakane's, and some kind of change to my still factory fender badges. Oh yeah, and lower the truck back down.
Hope to have it all done before TS Outlaw 2012.
Agjake11
Rosenberg TX
Currently saving up to do
Injectors 175's or 190's
Studs and hg's
Machine heads
Airdog II
Sump
Regulated return
And possibly a powermax after I do the list above
B.Warning
NE Missouri
On the list to do before winter ends...
Cervini hood
Pmf traction blocks/bars
Adjustable 3 link arms
Fab up a dual shock frt set-up with Remote resevoir shocks
Dual steering stabilizer
Re-tint windows darker
Possibly try to tackle switching my interior to black head liner, carpet, dash, door panels but leaving wood grain and king ranch seats.
Not enough hours in the day to do my stuff plus, work and family time.
