sunrisefordparts
Need prices for a 2015 f250
-Rear Driver side door handle.
-Set of stock fender flares that come on king ranch models
Paint code is J7 magnetic metallic. Are either of these items available prepainted?
neither will come painted
handle list $92.67 sell $66.72
front flares list $191.92 each sell $138.18 each
rear flares list $193.58 each sell $139.38 each
$20 to ship flares
q#421828
Right Angle
2008 F250
Looking for a price on 8C3Z-6012-ARM. I can pick this up from you, no shipping needed.
Does Ford have a gasket/seal kit for long block install?
Also, do you know if the the core can be returned to any dealer?
sunrisefordparts
2008 F250
8C3Z-6012-ARM list $10040.34 sell $8567.00 w/exchange (core $3000)
as for a gasket kit they have one for a short block install but as for the long block it would be gaskets as needed. ford has the turbo install kit and the rest would be individual gaskets.
joe d
monroe mi
Giant nut on outside of oil pan that holds dipstick tube to pan. 96 7.3 shipped to 48161 and how long does it normaly take. Thanks joe
Right Angle
Thanks. Do you know the lead time on an engine after you receive the order?
Can I also get a separate quote for the follow please?
Same truck, VIN: 1FTSW21R08EA40514
8C3Z-9G805-B Fuel pump gasket
8C3Z-9T514-C Turbo install kit
8C3Z-6A664-B Breather hose
8C3Z-6A665-A Emission filter
W303639 Crankshaft pulley bolt (pack of 4)
7C3Z-8620-P Serpentine belt dual alternator
9C3Z8620B A/C serpentine belt
8C3Z8501B Water pump
8C3Z8507B Water pump gasket
Injector o rings and seals
Copper gaskets for fuel cooler and fuel return lines
Hydroboost seals for lines to hydroboost unit
Turbo oil feed line
If this group of parts is available by Tuesday I can pick it up, if not, can you include shipping to 94553.
Thank you.
sunrisefordparts
Turbo oil feed line
Thank you.
heres your quote. shipping would be about $45 since the weight of the pump.
  • Q422776.pdf
