Zmann
cooler was OK despite Ford and UPS
that puppy was floating around in the box with no protection for the fins at all
and just some paper at the around the perimeter
the box had a footprint and two big holes in it but only a few fins were bent
thanks again !
sunrisefordparts
thanks again !
well that's good, sometimes we just get lucky with the way ups ships things.
ford_trck
Vail, AZ
Early 99 F-350 Single rear wheel 4x4.
Front unit bearings and mounting studs
the vacuum seal
outer axle seals
axle u-joints
Hope I don't need them but the stub shafts also.
sunrisefordparts
the vacuum seal
outer axle seals
axle u-joints
do you know if your truck is 4 wheel abs or just rear wheel abs?
sunrisefordparts
Just rear ABS
hubs list $477.32 each sell $343.67
vac seals list $63.67 each sell $45.84 each
axle seals list $28.75 each sell $20.70 each
axle ujoints list $61.20 each sell $44.06 each
stub shafts list $227.55 each sell $163.84 each
shipping for hubs, seals, and ujoints $35
q#431509
Strokin572
Billings, MT Local 406
Looks like engine mounts and everything are discontinued for a 95 F350? What about cab mounts, vacuum pump, all pulleys and water pump? Building a new engine may start with new everything.
Lugger007
Ct
need to replace egr core as clogged. Believe these are the numbers BC3Z-9V425-A and BC3Z-9P455-B.
Also need to replace def Reductant Quality Sensor Circuit. Can you please confirm it is included in the sending unit. BC3Z-5L227-K
2012 f250 xlt thank you
sunrisefordparts
heres a quote for whats available from ford, only a small handful of the pulleys are available.
  • Q431660.pdf
sunrisefordparts
bc3z-9v425-a list $305.43 sell $219.91
bc3z.9p455.b list $60.33 sell $43.44
as for bc3z-5l227-k that is the def pump kit. list $370.07 sell $266.45
q#431666
Lugger007
Ct
q#431666
I just called and tried to pay over the phone. Was told by parts department that over the phone is no longer accepted. Please advise?
sunrisefordparts
Yeah we had some bad cards come across and stiffed for some money so out business office said no longer taking cards over the phone. I can send a paypal link in Monday that if you don't have a paypal you can I put your card and use it that way without creating an acct.
Lugger007
Ct
Ok. That sucks about the problems. Yes, please send a paypal link
