Hoosierdaddy
2017 F350 DRW
HC3Z-8200-EB / Platinum grille assembly
HC3Z-16038-CA / 450 fender flare
HC3Z-16039-CA / 450 fender flare
HC3Z-16038-BPTM / 450 flare extension bumper
HC3Z-16039-BPTM / 450 flare extension bumper
HC3Z-17757-FPTM / PTM front bumper
HC3Z-17906-LPTM / PTM rear bumper
Can I get prices on these items and approximate shipping to 81507?
Thanks
Holdpoint
price quote with shipping to 75002
2015 f250 platinum 4wd
-front brakes
-front rotors (unless these can be turned)
-2 oil filters
-2 fuel filter sets
-1 trans filter
-rear brakes
-rear rotors (unless they don't typically need to be turned)
-four of the f150 door latches people are talking about swapping on their super duty's
sunrisefordparts
-front brakes
-2 oil filters
-2 fuel filter sets
-1 trans filter
-rear brakes
heres the quote for this stuff, if you end up needing the rotors there will be a little freight if they are trunable then shipping will be free.
  • Q480375.pdf
sunrisefordparts
Complete rear diff, can I get a price on a set of u bolts and nuts as well? I have the overloads. Price on the transmission mount that goes under the transfer case on the crossmember.
ford wont sell a whole diff assembly unless its current model year. as for the u bolts is it spring straight on axle or do you have the factory blocks?
ccmac
Texas Panhandle
Alright, thanks, figured I'd check. Wrecked my pickup a while back and keep finding more stuff the body didn't fix. It has a tall factory block, may also need the shackles as well.
sunrisefordparts
let me get the last 8 of the vin and ill get you some pricing on the parts.
ford_trck
Vail, AZ
Early 99 F-350 ZF6 4x4 with ESOF, CCLB
Reverse sensor pigtail and sensor
Transfer case 4x4 light pigtail. It is the 2 wires with spade connectors
Slip Yoke Boot for the rear drive shaft
Rear axle vent and the plastic piece that is in the end of the line
sunrisefordparts
heres the quote for these parts.
  • Q480935.pdf
C2tuck
North Texas
Ok. Thanks. As this is a work truck they aren't going to spring for that kind of money. Gonna go with LED fogs.
sunrisefordparts
What do y'all want for a platinum grille for a 15? Are those available in paintable?
only the surround is paintable, the center bars will remain chrome, or satin like most of the platinum trucks. and let me tell you how expensive the center bars in the platinum run.
dsberman94
Pennsylvania
I had the driver side hinge on the tailgate lock up onto the body hinge. Using the tailgate caused it to snap off. Is the tailgate hinge piece a bolt on part or do I have to drill out welds and weld a new one on the tailgate? If you send a diagram I can tell you what broke.
Also need the body mount for the driver side and I guess the full set of inserts for the gate. Can get a pick this weekend if needed. Out of town till then.
ford_trck
Vail, AZ
Quote is Q480935
I don't think the sensor and pigtail is right...
The pigtail looks similar to this
