sunrisefordparts
-Fuel injector return line kit
-oil cooler kit
-turbo pedestal gasket
-serpentine belt
Also need the cage nut that goes on the cab bolt behind the passenger side front tire
When removing the cab, the bolt broke off inside this nut
Shipped to 30189
Sent from my iPhone using Tapatalk Pro
are you looking for the oil cooler and gaskets, or just the gaskets?
and do you want the gasket between the turbo and pedestal or the one under the pedestal?
sunrisefordparts
Oil cooler and gaskets
Underneath the pedestal
Thanks!
-Fuel injector return line kit: List $189.69 -- your cost $114.76
-oil cooler kit: List $100.90 -- your cost $67.80
-oil cooler gaskets: your cost $12.88 for all three
-turbo pedestal gasket: List $12.42 -- your cost $8.57
-serpentine belt: List $53.04 -- your cost $33.55
that cage nut is going to be serviced in the reinforcement-
List $59.02 -- your cost $40.72
cab bolt: List $4.33 -- your cost $2.60
shipping would be $25.54
thanks,
Sean
q586875
Motostroker
thanks,
Sean
q586875
Ok I want to get those parts on the way.
PayPal?
rockygraz31
2010 F-250 Crew Cab 6.4L PowerStroke body mounts
And
2011 F-350 Crew Cab 6.7L PowerStroke body mounts
Sent from my SM-G965U using Tapatalk
sunrisefordparts
And
2010 F-250 Crew Cab 6.4L PowerStroke body mounts:
List $552.06 -- your cost $346.62 (just the mounts, no hardware)
+ shipping
Q587010
2011 F-350 Crew Cab 6.7L PowerStroke body mounts :
same List and cost $552.06-- $346.62 (mounts only)
+shipping
Q587012
thanks,
Sean
Motostroker
2018 6.7 powerstroke
-turbo install kit
-exhaust manifold gaskets
-(8) screws that hold heat shield to exhaust manifold
-vacuum pump to front cover gasket
2015 6.7 powerstroke 4x4 crew cab
I need this vacuum hose assembly (has both big and small together) these connect to bottom of degas bottle, I broke the small hose accidentally while installing battery box.
Motostroker
-turbo install kit
I also need a front cover seal kit and RTV kit to reseal front cover on the 18 model. Front cover is leaking bad
sunrisefordparts
The tube is going to be part of the vac reservoir, see attachments...
thanks,
Sean
  • Q588527.pdf
  • tmp.pdf
sunrisefordparts
MAP Sensor Pigtail early 99 F-350. Can you send me the part number too so I can make sure it's the right one?
Hi,
3U2Z-14S411-EXB list $37.65 -- your cost $23.82 +shipping
I have attached a pic....
thanks,
Sean
q588546
