sunrisefordparts
2008 F-350 SRW 6.4 2 door Regular Cab 4wd
Cab bolts and nuts
Bed bolts and nuts
Front and rear bump stops
Fan Clutch
Also anything else that needs replaced from pulling the cab (already have the stuff for the engine headgaskets up I got from you last week)
A/C line o-rings etc... you know better than I do
heres the quote for the bolts and bump stops and fan clucth, i added the ac orings that should be needed and the power steering teflon orings that should be needed. you should be good for the most part, but if i think of anything ese i will let you know or anything else you want just let me know.
  • q313936.pdf
purpleheart350
Rokwall, Tx
Do you have an 2001 excursion Dana 50 axle seal kit?
Hub knuckle o-ring
Hub lock vacuum o-ring
Axle dust seal
Axle vacuum seal
Wheel bearing
sunrisefordparts
Hub knuckle o-ring
Axle dust seal
Axle vacuum seal
Wheel bearing
ford doesnt have a kit it would be each part individually, and the bearings are in hub assemblies. heres the quote in the order of your list.
  • Q314022.pdf
Twinturbostroker
El Paso, Tx
Got my passenger side window button, but looks like I'm gonna need my driver side window buttons too....05 regular cab F250, thanks!
Also a quote, if you can get them.......05-07 F450 front bumper flares, that stick out on the side of the bumper for the wider track, thanks again!
sunrisefordparts
switch list $118.32 sell $70.99
lh flare list $48.95 sell $35.24
rh flare list $48.95 sell $35.24
free shipping
q#314130
Twinturbostroker
El Paso, Tx
thank yo sir. on those flares i know they are larger then the ones on a 250/350 truck, and are a grained black finish not smooth.
Yea I got a "wide body" project going....and the fenders look killer, but the bumper needs some love now, a buddy suggest the 450 flares on the bumper.....once I get the measurement I'll let you know for sure, thanks again.
