ToMang07
Mainah!
Need the plastic buffer/piece that goes in the hinge on a tailgate on a 2004 F-150.
Sent from the pocket porn device.
Twinturbostroker
El Paso, Tx
heres your quote the body bushing are listed from front to rear, the number ending in 54 is upper and 55 is lower.
Ok so here goes lol......
For the 2004 6.0, I need 2 push rods PN 8C3Z6565B.....is it possible to get the driver side head gasket and is there a master top end gasket kit for the intake, EGR, turbo, etc etc???
And for the 2006 F350 we are just gonna do the rear most cab bushings upper and lower
7C3Z1000154LB
5C3Z1000155B
Thanks!
sunrisefordparts
7C3Z1000154LB
5C3Z1000155B
Thanks!
there is a kit that does the egr cooler, turbo etc doesn't include intake gaskets themselves as ford believes they are reusable unless damaged that kit list $117.60 sell $91.73
intake gaskets list $15.09 each sell $11.77 each
as for the head gaskets would need to know if its a 18mm or 20mm and it comes with stand pipe and head bolts.
Twinturbostroker
El Paso, Tx
Figured about the intake gaskets, so include them, it's an early 6.0 so it will need the 18mm dowel and really don't need the bolts as we are doing studs, but if it comes with it, they come with it.....thanks
sunrisefordparts
18MM head gasket kit list $197.94 sell $154.39 unfortunately they don't come separate.
Musclemckeester
Houston, Tx
Is there a replaceable mesh screen/filter where the catalytic converter housing bolts to the DPF housing? Mine came apart in my hands when I took the 2 pieces apart. I'm hoping I can replace just that...for a 2010.
sunrisefordparts
I believe that is part of the dpf, mucho monies my friend. sell price is $1618
