OBS-Addiction97
Didn't read the whole thread, can you check icp and ipr DC while cranking? You can also get a mechanical gauge and attach it to the head.
I had a similar issue when with mine recently. same symptoms.. Cranking i could see no oil leaking out of injectors. I gave it a sniff of drugs to get it started with VC off and then saw the oil leaking out from around an injector.. Alot of oil. I would say get it started and check injectors for leaks.. mine was very obvious.. make sure you put down diapers under the truck before hand...
The orings should look good, I just put injectors in about 2 years ago. Might be a bit of a pain, but I could try that.
