2000 E-450 7.3 Parts
farmall16
Springwater, NY
All parts are from a 2000 E-450 with a 7.3. 157K miles. All prices are shipped. Sold as is. PayPal accepted. If you need more information or pictures, call/text (585) 519-2579. Nick. Please no calls after 9PM Eastern time.
Van Turbocharger. Very little shaft play. Compressor wheel looks good. Exhaust housing bolts vibrated out. Would recommend a rebuild just to be safe $200
Injector oil spouts and bolts $20
Fuel filter housing $100
HPOP Reservoir with sensors and bolts $55
HPOP gear $25
Dual Pulley Tensioner $20
Van intake Y-pipe (Spyder) $45
Van accelerator pedal assembly with sensors $45
Hydroboost assembly. Plunger, spring and retainer were removed. Good for parts or reuse your old plunger, spring and retainer.(Unable to be tested. Vehicle had a blown brake line) $40
Master Cylinder (Unable to be tested. Vehicle had a blown brake line) $30
E-series oil cooler ends $65
4R100 transmission harness. Van had a transmission mounted parking brake. $75
Belt driven vacuum pump. Newer aftermarket $50
7.3 Engine. Was running when removed. Had a misfire. Possibly fuel related. No injectors, hpop or turbo. Long block. Valve covers and oil pan damaged on removal. Local pickup only. $200
montrese04
Dibs on intake spyder and dual tensioner....... inbox sent
Sent from my HTC One_M8 using Tapatalk
montrese04
This gent right here is prompt and awesome. I ordered and had it in like 3 days. I was like 😱
farmall16
Springwater, NY
Updated list and prices. Looking to clean out my garage.
Van Turbocharger. Very little shaft play. Compressor wheel looks good. Exhaust housing bolts vibrated out. Would recommend a rebuild just to be safe. $150
Fuel filter housing $75
HPOP Reservoir with sensors and bolts $45
HPOP gear $20
Van accelerator pedal assembly with sensors $40
Hydroboost assembly. Plunger, spring and retainer were removed. Good for parts or reuse your old plunger, spring and retainer.(Unable to be tested. Vehicle had a blown brake line) $35
Master Cylinder (Unable to be tested. Vehicle had a blown brake line) $25
E-series oil cooler ends $50
4R100 transmission harness. Van had a transmission mounted parking brake. $50
Belt driven vacuum pump. Newer aftermarket $45
farmall16
Springwater, NY
Fuel filter housing $50
HPOP gear $20
Belt driven vacuum pump. Newer aftermarket. $45
farmall16
Springwater, NY
HPOP gear $20
