2000 f250 axles and suspension
RHCDIESEL
Imported Yankee to the south
I have the stock suspension,axles differential,drive shafts all the crossmembers in the front suspension. The truck is a 2000 CC 4x4 lariat short wheel base 373 gear ratio. its located in leesburg ga.
tag on front diff
stamp on spring pack of drivers side
Front complete axle assembly with springs shocks mounts driveshaft and all the linkage that connects them.$1100 and thats a package deal, if i seaperate prices will not be cheaper than what you would get in package.
transfer case sticker
transfer case,rear drive shafts,rear axle assembly,springs and brackets $1100.
if you buy it all ill take 1800
