yzrmbsg
So last Monday morning I remote started the truck like I do every day. Truck is always plugged in and I have a 30sec delay from the time the remote start is activated until it begins to crank. Truck starts up like normal, I don't watch it start, can just hear it. It runs for about 5 min before I go outside to seeing it pumping out white smoke. Oil temp is at about 80°-85°, it sounds like its running normal on high idle at about 1000rpm. I tap the break to deactivate the high idle and I notice a strange ticking noise, sounds like maybe a weak injector on the driver side. (I have no idea).
Still pumping out the white smoke, I figured it would go away when warmed up.... Around 150° or so I finally noticed it to get better. By the time I got to work, it had reached about 170° and I couldn't notice any more white smoke.
Monday night leaving work (not plugged in) started right up, pumped white smoke all the way home, about 13miles.
Didn't do it again until Saturday night, not plugged in, smoked the 15 miles to the movies. Sat for 2:30hrs, started fine, smoked all the way home.
Then again this morning, same story as last Monday, smoked all the way to work, and all the way home from work.
My oil temps do not get above about 180° most days. Normal operating temp is around 200° +-5°, in the warmer months that is.
The smoke does get less and less as the motor warms up, but it doesn't go away. From what I have found in my online searches is injector o-rings, cups, broken nozzles or any combination of the 3 could be the culprit.
I've ruled out glow plugs and relay because that should only effect the starting, not the continuous running. And it starts just fine. Am I right?
Just replaced ICP sensor and pigtail a few weeks ago. Oil/Oil Filter and fuel filter replaced 2500 miles ago. ICP is at 500ish and around 11%-12%dc at warm Idle.
Only thing out of the ordinary that I can think of is, I did the CCV mod a few months back and when I flipped the doghouse on top of the valve cover 180° I put 2 brand new o-rings there and one of them is now seeping oil.
No signs of power loss, idles fine, drives fine. No codes on the CTS besides the AIH delete for my boost gauge install, which never goes away.
Anyone have any ideas? Other things I can look at?
Haven't been able to find anyone locally with an AE and want to do what I can before paying for someone else to check it out.
Sorry for the book, just want to be thorough!
