cbly
Need some help here, I believe my brake control switch has gone bad, but not sure, don't want to just throw parts at it.
Problem: I have an electric brake controller installed for towing, and when I plug in my trailer, the green light will not light up, and the electric brakes wont work, however I can use the manual lever and the brakes function properly. All the lighting on the trailer functions properly, along with the brake lights. I have towed the trailer with another truck and the brakes work fine. I also had the brakes checked out at the RV shop last time it was in for repairs and everything checked out good.
I have installed a new 7 way connector on the truck, new pigtail on the trailer and also change the electric brake controller out, and still get the same thing. I read where it could be the brake pedal switch, but if this was bad, would the brake stop lights on the trailer still work?
Hope someone has had this issue and can point me in the right direction.
Also have checked all fuses.
CBly
CBly
